Wytze01
Mar 24, 2018Aspirant
Can't connect to internet with the router, even when the LED is on.
as far as i'm aware, I've tried everything. Overnight my router stopped providing internet to my devices. Wired or not, no connection. Restarted the modem, restarted the router, pulled all the cables...
- Mar 25, 2018
That is a cable modem-router. You can tell by the number of LAN ports on the back. >1 = router.
So you have two routers trying to allocate addresses and manage the traffic of devices that you connect to your network.
If you cannot put it into bridge mode, then you could try putting your WNDR3700v5 Netgear router into access point mode. This will disable its router features.
>> Click here >> WNDR3700v5 | Product | Support | NETGEAR << Click here <<
See page 127.
Be warned that in AP mode, the WNDR3700v5 will lose some features.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
michaelkenward
Mar 25, 2018Guru - Experienced User
When messing around with a network it is important to do things in the right order.
- Turn off and unplug the modem.
- Turn off the modem router and computers.
- Plug in the modem and turn it on. Wait 2 minutes.
- Turn on the modem router and wait 2 minutes.
- Turn on the computers.
- Wytze01Mar 25, 2018Aspirant
Thanks for your reply.
I've restarted the network in the order you told me in your comment, and after 3 full restarts, nothing has changed. It says it works, with the LEDs on indicating connected devices can access the internet, but they can't. However, after a restart, there is a short period of time in which it does work. It's a couple seconds, but that probably means it isn't completely dead. Are there other things I could try to save it? I've owned this router for 2 years, and most of my routers that I've owned died after 3 times that lifespan. Those weren't netgear routers. I'll await your response. Thanks in advance.
- michaelkenwardMar 25, 2018Guru - Experienced User
What modem are we talking about here? And how is it set up? Bridge (modem only) mode?
In your first message you say:
Other devices get access to internet via the cable from the modem.This suggests that your modem may also be working as a router. So you may have two routers in there, getting puzzled as to which is in charge.
I have recieved a modem from my internetsupplyer (if that's how it's called...), which recieves all the internet. The modem is via an ethernet cable connected to the Netgear router. The Netgear router is the second router in this instance, and has always behaved that way.
I do not know in which mode the modem is in. After looking on the site (to make changes), i didn't find a way to change this.
With my statement, i meant that all devices except the Netgear router can connect to the internet via the ethernet cable. The problems start when that ethernet cable from the modem gets plugged in the Netgear router, because the router won't send internet to connected devices with that Netgear router.
New Info: once the cable from the modem is connected with my Playstation (the "pc" i'm using), it shows up as an ethernet connected device (on the site of the modem, just like Netgear Genie) , but when I connect the cable from the modem to my Netgear router, it doesn't show up as an ethernet connected device. It did show up before the router stopped functioning correctly.
