pinskyjl
Jul 02, 2021Follower
can't connect to internet
Had a Power outage. Trying to reconnect to internet with my netgear26. It appears to be connected when I go to settings on my phone or other device, but then when I try to do something I get the me...
antinode
Jul 02, 2021Guru
> [...] Trying to reconnect to internet with my netgear26. [...]
"NETGEAR26"? Either way, it's not a model number. Look for "Model"
on the product label. Firmware version? Connected to what?
> [...] It appears to be connected [...]
Thanks for your analysis, but it would be more helpful to describe
actual behavior, and let others decide what it all means.
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read.
Look for the LED descriptions and "Troubleshoot".
> [...] when I try to do something [...]
"something"?
None of that is a useful problem description. It does not say what
you did. (It does say what happened when you did it.) As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
