Sparrowofthesea
Oct 26, 2021Aspirant
Can't Connect to one website only, Router Blocking?
So yesterday I could not connect to Visible website, I thought at first the website was down. But its not, its my Router. I had my router for years and I always was able to visit Vibible until yester...
Oct 26, 2021Guru - Experienced User
2 things to try.
1. Try using a different dns provider. Try googles at 8.8.8.8 or 8.8.4.4
2. try enabling ipv6
- SparrowoftheseaOct 26, 2021Aspirant
I will try the first step, how do you find where is the ipv6 setting at?
- plemansOct 26, 2021Guru - Experienced User
when you log into the router, go to
Advanced--->Advanced--->IPv6
Try the auto connect option .
