Whiskeydash
Oct 22, 2012Guide
Can't connect to ReadyShare
Hi, I've spent the last few hours going through pages on this forum and still haven't found a solution to my problem. I can't access the hard drive connected via usb to my wndr4500 through my wi...
obarthelemy
Feb 13, 2013Tutor
I know this topic is kind of old, but that's what came up when I googled for the same issue.
Actually, entering \\readyshare in an Explorer window let me access the drive. Not *Internet* Explorer, just plain old Windows Explorer. The drive doesn't show up anywhere else (not under Computer, the web interface says Offline...)
It's the only way I can access it, so thank you Aurora420 :-)
Aredub
Jul 19, 2022Tutor
I solved this problem a while ago, but it happened again today (perhaps related to the latest Windows 10 updates?). After several hours of troubleshooting, the solution was to log into the Netgear Genie app, go to the ReadyShare tab, and enable Network Neighborhood/MacShare. I had to do it without an admin password -- turning that on have me an error that a non-password-protected folder is required.
