Whiskeydash
Oct 22, 2012Guide
Can't connect to ReadyShare
Hi, I've spent the last few hours going through pages on this forum and still haven't found a solution to my problem. I can't access the hard drive connected via usb to my wndr4500 through my wi...
Aurora420
Oct 22, 2012Aspirant
Also, you could try manually entering the share location into windows explorer URL bar (Or IE7/8). This probably will not help if you have something blocking access though.
Below are some examples of what I mean, check in your router and you will see the exact address for the USB drive. It's in the advanced tab, then storage, then advanced storage section
\\readyshare
Or
\\readyshare\Internal_Disk
\\readyshare\USB
\\readyshare
Or
\\readyshare\USB
