Whiskeydash
Oct 22, 2012Guide
Can't connect to ReadyShare
Hi, I've spent the last few hours going through pages on this forum and still haven't found a solution to my problem. I can't access the hard drive connected via usb to my wndr4500 through my wi...
Aurora420
Oct 30, 2012Aspirant
Hmm, your last post about the Ready DLNA makes it sound like it's working properly, only some files would be shown via DLNA like certain movie, picture or music formats. So I think you are correct, it's something to do with windows settings, not the adapter or it's settings.
Keep in mind, windows or other firewalls and anti-virus may block some access, so until you get this sorted out I would uninstall those (Disable if using windows firewall, uninstall for all others as disable does not always do intended, especially for antivirus apps)
The only thing I can think of other than what I just mentioned is windows network discovery? See my posts here, the setting I mean is the one above what's circled in this post (Set for public and home)
http://forum1.netgear.com/showthread.php?p=422293#post422293
