Phases
Aug 24, 2017Initiate
Cant connect to router AC1200
Router wont let me connect to it, when i input password it thinks about it then says 'incorrect password' but when i input random letters it straight away says 'unable to join network', it also wont ...
- Aug 24, 2017
Problem solved.
Restored to factory settings
Phases
Problem solved.
- michaelkenwardAug 25, 2017Guru - Experienced User
Well done. Thanks for reporting back.
Always worth trying, even though some people are allergic to the idea.
