Md1
Aug 08, 2016Aspirant
Cant connect to samsung smart TV after changing to new router N750 premium edition WVDR4300
My old netgear was working fine with smart tv. But after replacing it with N750 ( replaced for faster speed), Tv doesnt even show the network , is anyone facing the same network/connectivity issue or...
- Aug 14, 2016
Solved - I had to reset the SVC and change the wifi region to "A"in TV, then reset the TV to factory setting.
Step 2 - reset the N600 and there you go, TV connected to WIFI.
Now the other TV i tried the same steps, but it didnt work. So i hooked up Apple TV( i had a spare one) and voila , it's working now.
michaelkenward
Aug 09, 2016Guru - Experienced User
Which smart TV?
Does it have WPS? That's a "press and connect" button that allows two wifi devices to see each other and connect.
Md1
Aug 09, 2016Aspirant
Model Samsung - one is UN46EH5300 and other one is 55". I tried WPS button, the green light blinks.TV showed my home network just for a second before the screen went blank, tried again but TV didnt show any network name at all ( green light on router was still flashing though when i tried second/third time). On the router, my security options are set as "WPA2-PSK [AES]" out of 4 below options:
None
WPA2-PSK [AES]
WPA-PSK [TKIP] + WPA2-PSK [AES]
WPA/WPA2 Enterprise
Please let me know if i gotta do something else either on the tv or router to make it work. Thanks.
- Retired_MemberAug 09, 2016
I would reset to factory defaults and try WPS before make any changes to router
- Md1Aug 09, 2016Aspirant
Ok so i reset it to factory settings but all in vain. Not sure what to do with this router. The last resort might be to return it and get a N600 i guess.
reset the TV
