Md1
Aug 08, 2016Aspirant
Cant connect to samsung smart TV after changing to new router N750 premium edition WVDR4300
My old netgear was working fine with smart tv. But after replacing it with N750 ( replaced for faster speed), Tv doesnt even show the network , is anyone facing the same network/connectivity issue or...
- Aug 14, 2016
Solved - I had to reset the SVC and change the wifi region to "A"in TV, then reset the TV to factory setting.
Step 2 - reset the N600 and there you go, TV connected to WIFI.
Now the other TV i tried the same steps, but it didnt work. So i hooked up Apple TV( i had a spare one) and voila , it's working now.
Retired_Member
Aug 11, 2016try a different channel 1,6 or 11
set mode to 54,
try without any security first
if successful then try adding security
Waiting for your response to post 10
Md1 wrote:I got 100 ft ethernet cable from Bestbuy the other day just to see if its the TV or the router or something else.
Unfortunately all this proves is you still have a problem and rules nothing out. Use the cable to check for firmware updates for the TV
Md1
Aug 14, 2016Aspirant
