fionna
Nov 29, 2015Aspirant
can't connect to this network
I finally see netwear44 in my list. I put in the key and it says cannot connect to this network.
- Nov 29, 2015
Yesterday, you said you were able to change the Wi-Fi password. Did it stop working, or did you never check to see if the new password worked?
Anyway, the password is case sensitive, so make sure you enter upper and lower case letters correctly.
