sandonpoint
Feb 02, 2017Aspirant
Can't connect to Wi fi devices - Model WNDR3400
Having trouble connecting internet to my TV/Blu Ray player. Both are brand new (top of the range) products. In Wi Fi connection section it says "cannot scan the wireless networks. Make sure your ...
- Feb 13, 2017
Ended up upgrading my router to a Nighthawk 7000. Solved my problem albeit at quite a cost.
Thanks for all your help,
Rob
William10a
Feb 05, 2017Master
[I can connect tablet/smart phone using wi fi.]
[Firmware needs updating. Tried to do so by logging into router but page could not be found.]
Is there a wired computer on the network?
That's the one to use to log into the router and update the firmware not a wireless device as you could make your router a door stop.
Log into 192.168.1.1 using a web browser and enter your users name and password when asked.
If all works allright you can do what need to router.
You will the version number of your router to get the right firmware for it.
The wndr3400v1 has a blue plastic doom over a led ring that lights up and flash when the wifi is in use.
The version number should be on the label on the buttom of the router.
The version one router does not how ever they change doom color on each version.
sandonpoint
Feb 05, 2017Aspirant
I am using a hard wired PC to try and update.
Model is a version1.
When I try accessing http://www.routerlogin.net.and also going through "genie" to update it comes up with the attached message on web.
With the Poweline product do you need to be on the same electrical circuit?
- ElaineMFeb 06, 2017NETGEAR Employee Retired
- William10aFeb 12, 2017Master
At least the breaker panel as long as all the homes circuits run from it. Here is thast firmware for the wndr3400v1 is 10.0.0.50 that's as high will go end of life product but it is still good little router. I have a copy of the firmware if you need it just let me know.
- sandonpointFeb 13, 2017Aspirant
Rob
