sandonpoint
Feb 02, 2017Aspirant
Can't connect to Wi fi devices - Model WNDR3400
Having trouble connecting internet to my TV/Blu Ray player. Both are brand new (top of the range) products. In Wi Fi connection section it says "cannot scan the wireless networks. Make sure your ...
- Feb 13, 2017
Ended up upgrading my router to a Nighthawk 7000. Solved my problem albeit at quite a cost.
Thanks for all your help,
Rob
William10a
Feb 12, 2017Master
At least the breaker panel as long as all the homes circuits run from it. Here is thast firmware for the wndr3400v1 is 10.0.0.50 that's as high will go end of life product but it is still good little router. I have a copy of the firmware if you need it just let me know.
sandonpoint
Feb 13, 2017Aspirant
Rob
