wrightstuff
Nov 19, 2016Follower
cant connect to wifi
I bought a wireless router from a yard sale and the network is a secure network and i dont know the password to connect to it is there anyway i can change or reset the password.
- Nov 21, 2016
wrightstuff You can always configure your own settings. Reset the router by using a paperclip to push the the reset button then reconfigure the settings by following the steps below.
I cannot access the Internet with my NETGEAR router
devindreb
Nov 19, 2016Aspirant
plug it in, push reset button, then use password settings on label on bottom.
admin, password after going to 192.168.0.1
ElaineM
Nov 21, 2016NETGEAR Employee Retired
