Adoregon
Jan 19, 2022Follower
Can't edit or create network folders on USB drive connected to router
I've attached a USB drive to the backside of my WNDR3400v3 router and followed the instructions to connect to it using readyshare. I've renamed the share to \\Router\USB_Storage. It appears in Wind...
michaelkenward
Jan 20, 2022Guru - Experienced User
Have you come across this?
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
