Retired_Member's avatar
Retired_Member
Sep 15, 2017
can't find 5g on laptop
I can't seem to find the 5G network on my laptop but I can see it on my iPad, I was able to see my extender's 5G network on my laptop before but now I cant find the 5G network for this router. (The m...
  • DexterJB's avatar
    DexterJB
    Sep 20, 2017
    Hi Retired_Member,
    1. Please check on your laptop's user manual or manufacturer to confirm that the laptop supports the 5GHz band. You can indicate the laptop model number in order for us or others to help out in the confirmation.
    2. If the laptop does indeed support the 5GHz band, please make sure that the drivers for the adapter is up to date.
    3. You can also try changing the channel for the 5GHz band.
    Dexter
    Community Team
