Retired_Member
Sep 15, 2017can't find 5g on laptop
I can't seem to find the 5G network on my laptop but I can see it on my iPad, I was able to see my extender's 5G network on my laptop before but now I cant find the 5G network for this router. (The m...
- Sep 20, 2017
Hi Retired_Member,
1. Please check on your laptop's user manual or manufacturer to confirm that the laptop supports the 5GHz band. You can indicate the laptop model number in order for us or others to help out in the confirmation.
2. If the laptop does indeed support the 5GHz band, please make sure that the drivers for the adapter is up to date.
3. You can also try changing the channel for the 5GHz band.
Dexter
Community Team
Retired_Member
Sep 16, 2017But I was able to see the 5G network for the wifi extender that I no longer have.
DexterJB
Sep 20, 2017NETGEAR Moderator
Hi Retired_Member,
Dexter
Community Team
- DexterJBSep 25, 2017NETGEAR Moderator
Hi Retired_Member,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- Retired_MemberOct 01, 2017
Ok not to be rude or anything but...
1. I don't have the manual with me.
2. It's already too late, I was only staying at some apartment which had a netgear router and I'm not there anymore.
(Sorry for the terrible capitalization on this whole conversation, I was only using it so it wouldn't be embarrasing.)
- michaelkenwardOct 01, 2017Guru - Experienced User
Retired_Member wrote:1. I don't have the manual with me.
Your laptop will tell you which wifi bands it supports. And the Internet is also a help it tracking down these things. Or tell us the model number of the laptop and someone will be able to find it for you.
Look for the wireless bit in network adaptors and see what that says. It will give you the details you need to find out the capability.
The biggest clue is that if it does not see 5GHz wifi, while other devices do, then it doesn't support it.
