kitsune
Mar 11, 2017Aspirant
Can't find admin page from win10
for some reason i cannot reach the admin page from my win10 pc. I can from other devices (kindle) but not the pc. I've tried to reset everything, turn off firewall, different browsers, updated java...
William10a
Mar 11, 2017Master
kitsune wrote:for some reason i cannot reach the admin page from my win10 pc. I can from other devices (kindle) but not the pc. I've tried to reset everything, turn off firewall, different browsers, updated java, etc. -- router and pc on private network (not public). I was using another NG router (n600) before with no issues.
'Bout ready to take it back, especially as I don't really see any performance boost. ugh.
Any ideas? anyone?
How are you rying to access the admin page from the win10pc?
kitsune
I've tried the genie app but uninstalled it. typically I just type the ip address in the web browser. the 1.1 one. I can reach it that way on my kindle but not on my win10 pc.
- William10aMar 11, 2017Master
kitsune wrote:I've tried the genie app but uninstalled it. typically I just type the ip address in the web browser. the 1.1 one. I can reach it that way on my kindle but not on my win10 pc.
So you had Genie and removed it. You tried and login by standard 192.168.1.1 on your mobile device and could but can not by a lan cable from your computer to via a lan port on the router correct using http://www.routerloin.net ?
Here is the link for the manual http://www.downloads.netgear.com/files/GDC/R6220/202-11443-04_R6220_EN_08Jan2016.pdf
- kitsuneMar 11, 2017Aspirant
not quite. My kindle and win10 pc are using wifi. Using browser with IP on both. Kindle can reach it. PC cannot. Kindle is on the 5g and pc on 24g
I'm pretty sure i could reach the page if I was hardwired but they are not close enough for wired.
To access the router via wifi with wireless login information on the bottom of the router.
