wolfy1961
Jan 18, 2018Aspirant
Cant find coustomer support to complain about having to pay for their problem.
Had to pay for their firmware update screwup.
- Jan 19, 2018
Something contracted out, but possibly less fishy than something you found in Google.
wolfy1961
Jan 19, 2018Aspirant
That's what the problem was.After installing the upgrade I could not access the internet. They charged me $94.00 to fix there upgrade. Don't seem fair to me. Just found a number to call and they will call in 3 to 4 hours. We will see.
michaelkenward
Jan 19, 2018Guru - Experienced User
That sounds more like a scam than official support. That is not the amount quoted by Netgear.
Gearhead Support - Netgear's Tech Support for Home PCs & Network Devices
Unfortunately, Netgear has no control over crooked offshore call centres.
I would be very very careful before allowing these people anywhere near my computer.
- wolfy1961Jan 19, 2018Aspirant
GearHead -1-888-615-3488 support is the number I called. So this is NetGear, right?
- michaelkenwardJan 19, 2018Guru - Experienced User
