alisha2602
Jun 16, 2017Follower
Can't find my network?
Internet is working fine on desktop computer, but can't access the wifi. When I search for my network on a wireless device, the network doesn't even show up anymore. It was working fine yesterday. I'...
- Jun 19, 2017
Hi alisha2602,
1. Are the 2.4GHz and 5GHz LED's lit? If not, try pressing the WiFi on/off button on the front panel as described on page 10 and 11 on the user manual linked below.
http://www.downloads.netgear.com/files/GDC/R6400/R6400_UM_11jun32015.pdf
2. The wired desktop computer may not be WiFi capable and that's the reason the Genie indicates that it is not enabled.
3. Please try using other wireless devices (smartphones, tablets, laptops).
Dexter
Community Team
DexterJB
Jun 19, 2017NETGEAR Moderator
Hi alisha2602,
Dexter
Community Team
- DexterJBJun 27, 2017NETGEAR Moderator
Hi alisha2602,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
