Jh5850
Jul 24, 2016Follower
Can't find QoS Priority Rule options for WNR1000v4
The subject pretty much covers it all. I wanted to set up priority rules and manage traffic by using the QoS options in the advanced settings for my router. But there's simply no option for priority ...
- Retired_MemberJul 25, 2016
Supports Wireless Multimedia (WMM) based QoS that's it no rules.
benbuzz790
Nov 06, 2016Aspirant
I had the same problem and it took many hours to find this post and figure out what was wrong. Take a look at this screenshot:
http://i.imgur.com/4WTuRFm.png
The Help Center clearly indicates that there *should* be more options on the screen, but as you said, they do not exist. Very bad and confusing design by Netgear here.
