thihacr1993
Nov 30, 2020Aspirant
cant find wifi router name
My internet service went out few times today so I had to restart to modem for like the first 2 times and my laptop and my phone was able to reconnect to the wifi just fine. But the last time I had my...
thihacr1993
Does it work if you're hardwired in? - I have not tried hardwired it yet but I'll check it out.
What are all the led's showing on it? - all the led are lighted up except the last 2 icons (one looks like 3 computer connected to each others and one looks like the USB icon)
Did the wifi on/off button get pushed during the resets? Push and hold it for 2 seconds. - I did push and hold it for few second the last time I tried it. The modem lighted up and works fine but no wifi name shown on my laptop and my phone
Nov 30, 2020Guru - Experienced User
did it somehow get set back to defaults?
Maybe its broadcasting under a different ssid.
I'd log into it hardwired and check the ssid/password info as well as if it works.
- thihacr1993Nov 30, 2020Aspirant
Thank you! I'll check that. Sorry but how do I log into the hardwired and check the ssid/password info? I tried to use either routerlogin.net or http://192.168.1.1 in the address bar to check but nothing shown. I'm using the internet on my phone at the moment.
- plemansNov 30, 2020Guru - Experienced User
connect a pc/laptop to the C6300. Then go to 192.168.100.1
- thihacr1993Nov 30, 2020AspirantThanks. I’ve connected the hardwire with my laptop. No WiFi name shown up neither. I was able to log into my my hardwired and checked the SSID. The SSID info has not changed. I’m not sure why it doesn’t shown my WiFi name. I tried to manually type the SSID name in my phone and it won’t be able to fine the network neither
