iduff's avatar
iduff
Can't get IPv6 on my MacBook Pro thru WNDR3700 then thru CM1000 to Comcast?
Hello, I have Comcast gigabit cable service coming into a new CM1000 modem. I get an IPv6 address on my MacBook Pro when I directly connect it to the CM1000. This leads me to believe that: Comcast ...
  • iduff's avatar
    iduff
    Aug 14, 2019
    DexterJB, thanks for following up. I discovered I need to reboot both my router and my modem, then all is good. Problem solved, thanks.
