robdog1977
Dec 07, 2022Tutor
Can't get USB storage device and USB printer to work together R6300V2
I've been using an R6300V2 for year with no issues. I've got a 500GB external drive on the USB 3.0 port and it works great. I recently attached an Epson Photo Stylus R260 printer to the USB port on t...
michaelkenward
Dec 08, 2022Guru - Experienced User
robdog1977 wrote:
I'm using an older firmware because when I try to do an update it tells me the file isn't the correct one for my router. I'm stumped!
I'd start by trying to fix that.
What version do you have now?
Don't forget, the V number is important. V1 firmware won't work on V2 devices, and vice versa.
We are talking about a device that is nearly a decade old so it may have problems with newer devices.
