robdog1977
Dec 07, 2022Tutor
Can't get USB storage device and USB printer to work together R6300V2
I've been using an R6300V2 for year with no issues. I've got a 500GB external drive on the USB 3.0 port and it works great. I recently attached an Epson Photo Stylus R260 printer to the USB port on t...
Dec 08, 2022Guru - Experienced User
There was quite a few r6300's made for ISP's that have isp specific firmware on them. So its helpful to know what actual firmware version you're on.
also, any chance you have a powered usb hub to try it with?
The R6300's didn't have much power envelope for their usb ports. It might be fine with 1 but 2 being enough to push it over the required power the devices need.
robdog1977
Dec 08, 2022Tutor
This router is one that was originally supplied by Charter (Spectrum). Right now it is running firmware V1.0.3.6_1.0.63CH, the newest version posted is V1.0.4.2_10.0.74. I realize that the V2 means version 2 and I am trying to install the V2 firmware.
- plemansDec 08, 2022Guru - Experienced User
Thats a charter communication router. It was sold to isp's and they gave it to customers. So the stock firmware won't work on it (unless you do some playing with ddwrt).
- robdog1977Dec 08, 2022Tutor
I found this info on another board. There is a DD-WRT firmware that you can use to flash the Charter R6300V2 that will allow you to use any of the factory Netgear firmware or DD-WRT firmware so I guess that's where I'll start.
- plemansDec 09, 2022Guru - Experienced User
You for sure can try that. And many do with great luck. And some brick their devices.
Its a risk you run into when flashing 3rd party firmware to it and then back to stock.
So just be a little cautions.
