Greeny173
Feb 01, 2017Aspirant
Can't Log in on Network Genie Login Page
I cannot logon using the Network Genie logon. It just sits there going round and round. I have used my Samsung Droid 2 with Network Genie and logged on with admin and my own password. I can lo...
- Feb 02, 2017
Don't know what I did other than turn the computer off last night and rebooted it this morning. Like they say "Even a blind squirell can find a nut" and that is what transpired in this case. Appreciate all the responses to my problem and appreciate you all being here for us novices when problems arise.
TheEther
Feb 01, 2017Guru
You don't need to use the Genie app. Make sure Windows considers your home network private, not public. Otherwise, it may not permit you to log into your router.
- Greeny173Feb 01, 2017Aspirant
When I attempt to use the internet login method "http://www.routerlogin.com/", I get the following reply,
"You are not connected to your Router’s WiFi network. To access routerlogin.com, your device must be connected to your Router’s WiFi network. Check your current connection and try again." Man, I am totally lost and almost regret disconnecting my RangeMax with which I never had a connection problem logging in.
- TheEtherFeb 02, 2017Guru
I'm not certain but there may be a bug with using www.routerlogin.com from a wired device. Did you try using the router's IP address?
Also, did you check Windows for the public/private network status?
- Greeny173Feb 02, 2017Aspirant
Did it both with 192.168.0.1 and again with 192.168.1.1 My network status reflects private. Really at a loss here. Everything seems to work but bugs me to not be able to get into my settings.
