whathaveidone
Oct 06, 2021Aspirant
Can't log in to R6400 after putting it into AP mode
To expand on the title: I'm using a Nighthawk X6 as my primary router, connected to the modem downstairs. Since this is in a lower corner of the house, I decided to add my old R6400 into the mix...
Oct 06, 2021Guru - Experienced User
Try (LAN port from X6 to LAN port of R6400)
- whathaveidoneOct 06, 2021Aspirant
I tried that just now. Same results - internet works, I can ping the 6400, but navigating to the address in the browser results in a simple "this site can't be reached" error.
- plemansOct 07, 2021Guru - Experienced User
a couple questions.
What is the x6 connected to? (gateway/modem)
What ip address is the x6?
what ip address is the r6400?
- whathaveidoneOct 11, 2021Aspirant
Sorry for the late reply; been out of town and haven't had time to look at this.
We've got a pretty run of the mill fiber modem handling the optical to copper conversion (prior to that we had cable internet - different modem, exact same problem though).
It's your typical x.x.1.1 address for the X6, and x.x.1.2 for the 6400.
