CorvieBat
Jan 29, 2024Aspirant
Can't log into my router, incorrect password
I'm having trouble logging into my router, every time it gives me an error saying my password is incorrect. Every time I go to log in on my browser on my computer, it doesn't even indicate it's conne...
Jan 30, 2024Guru - Experienced User
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 10 seconds then let go. Then log in to routerlogin.com or 192.168.1.1 using a wired PC and web browser and walk thru the setup wizard. Be sure write down all important information for safe keeping later on.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
CorvieBat
Jan 30, 2024Aspirant
I've tried both methods, nothing worked liked I mentioned in my earlier replies.
- FURRYe38Jan 30, 2024Guru - Experienced User
So with the Router disconnected from everything accept one wired PC and pressing the reset button for 10 seconds and release, giving 1 minute, does the wired PC not get a 192.168.1.something address and you can't get anything to pull up in a web browser at 192.168.1.1?
- CorvieBatJan 30, 2024Aspirant
Nothing really. I mentioned earlier it's not my primary router so that might be why. Even so I can't even access the router in the control panel because the password is incorrect.
- michaelkenwardJan 30, 2024Guru - Experienced User
Control panel?
