smoddelm
May 28, 2016Tutor
Can't log into router after recent firmware upgrade
Had been using my router as an access point and I don't think option to upgrade firmware was even available - or maybe I just never loggin to to see if it was. Anyway, I just reset the router to reg...
- Jun 01, 2016
OK, I guess I'll reset and buy a new one if it ruins it.
fivesmaster
May 28, 2016Initiate
Hi,
Thanks for posting, as I am having exactly the same problem, just factory reset my router, firmware upgrade, now genie will not let me in on admin/password. Netgear, let me know how to rollback to a previous firmware so I can login!
