TxGeek
Apr 06, 2022Aspirant
Can't login to my R6260 Nighthawk Router.
I've been trying to login to my R6260 for months without success. The Nighthawk App is perfectly useless. I've tried putting in the ip address of 192.168.1.1 several times only to be met with the m...
UtesGirl
Apr 10, 2022Aspirant
I had the same issue. Speaking to NetGear support, when using the Nighthawk app I did an update for the system which happened to be a corrupt file thus crashing the Router and No real chance of factory reset. NetGear advised to do updates through hardwired to computer direct to router. Why use the nighthawk app?
