maryr69
Jan 22, 2018Tutor
can't login to opendns
I'm having problems logging in to opendns. I keep getting messages about blocking sites because of content. I never set up parental blocks or anything. When I try to login, i enter my email addres...
- Jan 29, 2018
Hi maryr69,
If that is the case, you can factory reset the router and go through the setup. The link below may help out.
Reset: http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
DexterJB
Jan 25, 2018NETGEAR Moderator
Hi maryr69,
1. It is possible that someone may have enabled Live Parental Controls.
2. Please provide a screenshot of the message if possible.
3. If you are unable to find the credentials, a factory reset can be a way around it.
Dexter
Community Team
DexterJB
Jan 29, 2018NETGEAR Moderator
Hi maryr69,
Dexter
Community Team
