EDK2021
May 27, 2021Tutor
Cant login to router
Hi - I used to be able to login without issue. Now it redirects me back to https://www.netgear.com/home/services/routerlogincom/ I unplugged, cleared cache, tried a different machine - no luck. ...
EDK2021
May 27, 2021Tutor
XB6-T - thx for the help
May 27, 2021Guru - Experienced User
that gateway is a modem/router combo device.
it causes a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
options? (only uses 1)
1. put the xfinity box in passthrough/modem only mode.
2. put the netgears IP address into the xfinity's box DMZ
3. put the netgear into access point mode.
to access the router. disconnect it from the xfinity box. Reboot it.
Then with your pc/laptop connected to it, check its ip address. (pull up command prompt and type ipconfig, the default gateway will be the routers ip address)
From there you should be able to access it .
- EDK2021May 27, 2021Tutor
thank you -
