Swabbie
Mar 28, 2022Tutor
CANT LOGIN TO WNDR4300 TO SET UP AS REPEATER
I trying to make use of this old router and set it up as a wifi repeater. Since its a 2015 product its no surprise that logging into "routerlogin.net" with hope to log in with default "user" "pas...
Mar 28, 2022Guru - Experienced User
Try disconnecting the router from the primary router.
Then factory reset it. Push and hold reset for 7-15 seconds while its powered on.
then (with it still disconnected from primary router) try to access it-set it up.
What version of the wndr4300 do you have? some have the wds option removed.
You could use it as an access point.
