goarv
May 31, 2020Tutor
Can't login to www.routerlogin.net.
 I want to change my network name/password from the default setting, and I can't log in to www.routerlogin.net,. or the IP address. I have tried to delete history using both Chrome, and Internet.  Any...
- Jun 01, 2020If you can't connect to routerlogin.com or routerlogin.net, try these troubleshooting steps: 1. Turn on the power for the Netgear router.
 2. Connect a computer to the router's Wi-Fi network.
 3. Connect to the websites using the router's default IP address at http://192.168.1.1. This won't work if you changed the default IP.
 4. If problems persist, connect with a different browser or wireless device.
 5. Power-cycle the entire network.
 6. If all else fails, perform a factory reset on the router.I hope it might help to solve your problem.
bryan441
Jun 01, 2020Star
goarv
Jun 01, 2020Tutor
Thank you! I will try this tonight, appreciate your help.
