norrmanj
Nov 17, 2020Aspirant
Can't manage to port forward with Orbi
I have opened alot of servers before but now i have problems with opening my ports on my orbi router and i don't know what to do about it. When i use my portchecker it just tells me that connection timed out. I have UpnP disabled and i have set up a static ip adress (tried without it aswell). I have tried to disable my firewall and my antivirus program but to no help. Any sugestions is appriciated
> Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Firmware version? Connected to what?
"Can't" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.Why, exactly, are you trying to configure port forwarding?
> I have opened alot of servers [...]
"servers"? With what kind(s) of "servers" are we dealing?
> [...] When i use my portchecker [...]
What, exactly, is your "my portchecker", and what, exactly, did you
do with it where?> [...] i have set up a static ip adress [...]
How? For what?Terminology: A "static" address is configured on the device itself.
What you configure on a (DHCP server on a) router is a reserved dynamic
address, not a static address. Are you talking about Address
Reservations on the Orbi, or actual static addresses configured on the
device itself, or what? What, exactly, did you do?> [...] i have problems with opening my ports [...]
In my experience, people who talk about ports being "open" or
"closed" often don't understand the problem.For the usual problems with port forwarding, see:
- norrmanjAspirant
Sorry everyone for bothering you. I was to vague in my post. Turns out it was me that was dumb:D. I have two routers now that we got fiber installed and that is why it did not work since i only had the ports on my orbi router opened and not my telia one. Sorry again ty for your help anyway!
