Gabreil
May 10, 2020Aspirant
Can't port forward
Hello, for the past year or so I've been trying to port forward the port 25565 to host a dedicated Minecraft server for me and my friends. I was always able to join with my local ipv4 address but my ...
- May 13, 2020
> If you look at the picture I uploaded, you can see that the question
> "Does your Internet connection require a login?" is answered No. [...]That's an argument between you and your ISP. If you have Internet
access, then that's not the problem.But, while we're looking at that picture...
> https://community.netgear.com/t5/x/x/m-p/1859106
> Does the IP address of the WAN/Internet interface of your router
> match what you're using as your public IP address from the outside
> world? ADVANCED > ADVANCED Home : Internet Port : Internet IP AddressBASIC > Internet : Internet IP Address : IP Address (as shown in your
picture) provides the same critical fact: 100.68.<blur>.<blur>. Plug
that address into the form at: https://whois.arin.net/ .As you can see, that's not a public IP address. My guess would be
that your ISP is using carrier-grade NAT, and that's defeating your
attempts at port forwarding.https://en.wikipedia.org/wiki/Carrier-grade_NAT
The only solutions I know are: 1) to ask your ISP for a real public
address (for which they might charge more), or 2) to use a tunneling
service like the one mentioned in another thread (near the end):https://community.netgear.com/t5/x/x/m-p/1748431
Some ISPs do not permit servers for residential customers, but I'm
confident that they'll tell you that if you ask.
antinode
May 10, 2020Guru
> Router: NETGEAR R6220, Router Firmware Version V1.1.0.86_1.0.1
Connected to what?
- GabreilMay 11, 2020Aspirant
What do you mean, I don't understand which part of the text you're referring to.
- antinodeMay 11, 2020Guru
> referring to.Pretty much all of it. Start at "The usual problems with this stuff
are:", and answer the questions?- GabreilMay 11, 2020Aspirant
Well you see, I don't have a lot of knowledge about internet/router tech. I know some of the basics I guess but not any more than that.
I looked into the discussion you linked but I'm not sure if any of those are my problems, since I don't understand all of it. The first paragraph was about "Wrong External IP Address" and I am trying to port forward 7777. Is this the right way to do it?(Check screenshot) When I choose Internal IP Address I should choose my desktop pc/the device I'm trying to host the server on, right?
