jglende
Feb 19, 2018Tutor
Can't reinstall WNR2000v2 router software with disc.
I want to update the firmware for my out-of-support period WNR2000v2 router. When I disconnect my wifi and run the installation disc, the first thing that happens is a message that there is no worki...
DexterJB
Feb 19, 2018NETGEAR Moderator
Hi jglende,
You can manually update the firmware of the router. The links below may help out.
http://kb.netgear.com/app/answers/detail/a_id/23960
Dexter
Community Team
jglende
Feb 20, 2018Tutor
Dexter--thanks for your response. I actually got this far when I first tried to install the new firmware manually: after connecting my ethernet cable directly to my computer, I visit the download page, download it, extract it and then visit the routerlogin site. I get the message that I am not connected to my wireless router. But I don't know how to do that if my ethernet goes directly from the modem to my computer--seems like an impossibility.
That is why I dug out the original installation CD, hoping to log in to the router that way. Then, of course, I got the "ethernet is not enabled" message. What now?
- antinodeFeb 20, 2018Guru
> [...] then visit the routerlogin site. I get the message that I am
> not connected to my wireless router. [...]
Welcome to what may be the worst error message in the world. For an
explanation, try:
https://community.netgear.com/t5/x/x/m-p/1365830
Briefly, the idea is that "[www.]routerlogin.net" should point to
your own router, but that's true only if you use your own router for DNS
name resolution. Irregardful, you should be able to get to the thing
using its IP address, if you can determine (or guess) that. Perhaps:
"192.168.1.1". You can often get it from your computer's IP
configuration as the default gateway or router address (or some similar
description).
> [...] But I don't know how to do that if my ethernet goes directly
That's only one of the problems with that misleading/unhelpful error
page. But I wouldn't hold my breath waiting for Netgear to improve it.
Try the IP address in a web browser. Forget the obsolete software on
the CD.- jglendeFeb 21, 2018Tutor
Thank you antinode. I'll attempt your solution when I understand exactly what you've said; I'm really a novice at networking.
