PSE
Jan 15, 2018Aspirant
Cant see backup drive in nework after firmware update
I recently update the firmware to v1.0.4.16 after recieving email from negear. Now I notice that the backup usb drive is not showing up in the network in file explorer. It did prioor to the formwa...
- Feb 20, 2018
Hi PSE,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
Dexter
Community Team
DexterJB
Feb 06, 2018NETGEAR Moderator
Hi PSE,
Have you tried re-mapping the ReadySHARE drive? If not, please try doing so.
Dexter
Community Team
DexterJB
Feb 18, 2018NETGEAR Moderator
Hi PSE,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- PSEFeb 19, 2018Aspirant
Thanks for the follow-up. Once I mapped the network drive everything is good.
Paul
- DexterJBFeb 20, 2018NETGEAR Moderator
Hi PSE,
Dexter
Community Team
