Isaiah4110's avatar
Isaiah4110
Can't see devices connected to 2.4 GHz WiFi
I've recently purchased and configured a Netgear R6220-100NAS with both the 2.4 GHz and 5 GHz WiFi signals available less than a month ago and updated to the latest firmware when I ran my initial set...
  • Isaiah4110's avatar
    Feb 22, 2016
    Problem solved. I did a factory reset on the router (and manual reconfiguration) and I can now successfully print and ping devices on both WiFi networks. Looking at the configuration settings I backed up prior to the reset, it looks like wireless isolation was turned on for the 2.4 GHz WiFi network. It was set to "1" in the .cfg file.
    That was my suspicion from the start, but I couldn't find the setting in the router setup options.
