Rooyin
Sep 01, 2015Aspirant
Can't set Qos rule for mac address r6300
Hello, my r6300 would not let me set a qos rule for mac addresses. Whenever I try to set one up, it will display either duplicate policy name or if I change the policy name from Pri_MAC_XXXXX to ...
- Sep 24, 2015
Hi pesss,
Please follow the steps below if you want to prioritize the device that you are connecting from:
1. Select the radio button on the left of the device that you wish to setup the prioritization for.
2. Everything will be auto-populated.
3. Change the priority level (Low, Normal, High, Highest).
4. Rename the device (optional).
5. Rename the QoS policy (optional).
6. Click on Apply. Clicking on Add will result to the error that you are encountering.
7. It will then redirect you to the QoS Priority Rule list. Make sure the QoS policy name is on it.
Dexter
Community Team
Rooyin
