Blair55's avatar
Blair55
Can't stream video
I have a Netgear WNDR 4300 router and am trying to stream TV shows and movies via a USB 3.0 flash drive. When I play a show or movie the router will stop broadcasting. The lights for 2.4 & 5.0 stay on. I have to do a hard reset and then the router works just fine again. I don’t understand what I’m doing wrong. I’ve tried 2 flash drives with the same results. The files are in mp4 format.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    How? Stream to what?
    You don't say, but I assume that you have read the relevant bits of the manual.
    >>> WNDR4300 | Product | Support | NETGEAR <<<
    See page 60.
