PER43
Nov 05, 2016Follower
Can't turn on wireless
Recently installed router, everything was working fine. I turned off the wifi with the button on the router, now it won't turn back on. What can I do?
- Retired_MemberNov 05, 2016
It takes several seconds of holding the button
Still can't get it to work then Push reset until Power LED flashes
michaelkenward
Nov 06, 2016Guru - Experienced User
Which router?
