fillipov
Apr 17, 2023Follower
Can't update 6300v2 / file is incorrect
Trying to update 6300v2 router but it says file is incorrect. Tried a lot of different firmwares from this page https://www.netgear.com/support/download/?model=R6300v2 https://prnt.sc/zFAP9dvCw9B8 ...
michaelkenward
Apr 17, 2023Guru - Experienced User
Your subject isn't clear. Which 6300v2 ? R, C or D.
Probably the R6300v2 – just checking.
What says "file is incorrect"? How are you going about the update?
This is the best approach:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Remember, the download is a zip file that you have to unpack. You then have to "load" the firmware file into the router. You cant just "open" it.
