CM201
Jun 21, 2017Aspirant
Can't upload file for firmware update
Hi, I'm got stuck trying to upload the file during the firmware upgrade. I'm in Avanced Adminisration then click on Firmware upgrade. I click browse and click on the .img and click upload but get th...
- Jun 21, 2017
I was able to do it, i think. at the end it asked again for me to login to routerlogin.net but i think it worked. I got it to work either because i downloaded a file for the wrong rounter, because i did go back and re-did the download or it was actually busy and it finally let me do the upload. Another option is on the top of the home page of routerlogin.net it had a button that said "firmware avaiable for upgrade", that seemed to work to.
CM201
