kylestephens30
Nov 13, 2020Follower
Capped at 100mbps
Hi everyone, needing help with my NetGear 3500RP WiFi Extender. I have AT&T 300 internet and was receiving around 300mbps hard lined into my WiFi extender. I went through and changed the name & passwo...
schumaku
Nov 13, 2020Guru - Experienced User
kylestephens30 wrote:
... I have AT&T 300 internet and was receiving around 300mbps hard lined into my WiFi extender. I went through and changed the name & password of my WiFi and now I can’t get over 100mbps. ... The extender is receiving 300mbps but my computer only receives 100mbps from the extender, even though the output is set to 300. When I get into the extender and look, the LAN is at 100 and is maxed.
According to the WN3500RP Universal Dual Band WiFi Range Extender, Wall-plug Edition Data Sheet this device has a 10/100 Ethernet port only. The max link speed set is the PHY rate of the wireless radio, not the Ethernet interface. If you have seen higher link rates on your computer before, this was impossibly on the Ethernet link, much more the wireless interface.
