Ghila96
Nov 03, 2016Aspirant
Cascade Router
 Hello everybody,  I cascade Netgear DGND3700v2 to a modem of my provider (LAN to LAN). I followed this steps:     1) Adapt DHCP range (for main modem in set from 192.168.0.2 to 192.168.0.254 and its ...
- Retired_MemberNov 06, 2016
You're Welcome,
search the web for your ISP modem and or call ISP and ask them to place it in bridge mode OR purchase a Access Point.
Retired_Member
Nov 03, 2016Time info is routed thru the WAN port if WAN isn't used it will not update
Ghila96
Nov 04, 2016Aspirant
Thank you for reply,
There is no way to set manually time?
And for the other problem what is the solution?
Thank you!
- Retired_MemberNov 04, 2016
You're welcome,
You're using the router in a way it was not intended to be used, So it has limitations, when WAN port is not connected time won't sync, and turn off WIFI via schedule won't work either.
- Ghila96Nov 05, 2016Aspirant
I put router in cascade (LAN to LAN) because of provider router (that is imposed by my provider) limitation. So, if I put the router in cascade, but in LAN to WAN mode, I could solve both problems?
- Retired_MemberNov 05, 2016
No! you need an Access Point
