SriniK
Mar 18, 2025Aspirant
Centria 4700 AP Mode remote access of Readyshare
Hi, I have the Netgear Centria 4700 configured to run in AP mode. My home network is Eero mesh network. I am able to access the readyshare on any device within the network. How can I access the re...
michaelkenward
Mar 25, 2025Guru - Experienced User
Is that the WNDR4700, WNDR4720 from 2012? An interesting line that Netgear quickly abandoned.
How can I access the readyshare on the centria 4700 from outside?
A lot has changed since they made that thing. I suspect that the answer is that you can't do that.
Support for ReadyCLOUD feature ends spring 2023 | Answer | NETGEAR Support
In any case, AP mode also breaks quite a lot of features.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
You may have to find another solution to your problem.
First check the manual:
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Just another user with time on their hands.
