PaddyButler
Oct 26, 2020Aspirant
CG3000-2STAUS WiFi Router. Trying to configure as a WiFi AP but unable to route to internet gateway
I have an old Netgear WiFi router which Optus left me when I went on NBN. I want to use the old router as a WiFi AP to connect IoT devices to and keep these segregated from other devices on the home ...
antinode
Oct 29, 2020Guru
> I attach a diagram [...]
It might be safer/clearer to use a /24 subnet on each router. I
would not bet that anything else gets tested, and that'd make it easier
to see which addresses are in which subnet.
> [...] I suspect 130 is a second IP address for Router1. [...]
A router does not have _an_ IP address. Each network interface in a
router has an IP address. So, each router here has a WAN/Internet IP
address and a LAN IP address.
The WAN/Internet IP address on the CG3000v2 must be on the LAN
subnet of the main router. Documentation on the CG3000v2 seems sparse,
at best, so I'm not sure exactly where/how you'd configure this stuff.
(If it's possible. Normal Netgear cable modem+router models lack a
WAN/Internet Ethernet port. That makes then simple to deal with in such
a system: You can't do it. Exactly how much you _can_ do with a
CG3000v2 is not immediately obvious (to me).)
I'd configure the main-router LAN as "192.168.0.1/24" (perhaps with
its DHCP pool as ".8"-".254"); the CG3000v2 WAN/Internet interface as
"192.168.0.2/24"; and the CG3000v2 LAN as, say, "192.168.2.1/24".
The main router would then need a static route (not related to having
any static address) like:
Destination: 192.168.2.0
Subnet Mask: 255.255.255.0
Gateway: 192.168.0.2
I don't know how you'd configure that on your (unspecified) main
router.
Whether it would make sense to enable NAT on the CG3000v2 is not
clear to me. Some experimentation might be needed.
> I think I need to somehow assign WiFi R2 a static "internet" address
> from the WiFi R1's subnet. And then set the Gateway and DNS address to
> that of WiFi R1.
No. "WiFi" is not a separate network, or subnet, or anything. It's
just part of the LAN (subnet) of the relevant router.
PaddyButler
Oct 30, 2020Aspirant
Many thanks for your suggestions and advice, it has been a really helpful discussion for me.
I tried that (I used 192.168.1.0/24) and I agree it is easier but still no joy. In my main router (which is a Sagemcom F@ST3864V3HP by the way) on the LAN setup, there is an option to "Configure the second IP Address and Subnet Mask for LAN interface" which I selected and entered 192.168.1.0 and 255.255.255.0. This automatically created a route to that address from main router.
The problem seems to be in setting the WAN/Internet i/f address - there just doesn't seem to be a way of doing this. As I showed in the screenshot, there is no IP Address/Mask shown for the Internet port and no Default Gw or DNS and I cannot see how it can be set.
I think that is the answer unfortunately - No can do.
A final question - my main router by default, allows all outgoing IP traffic from LAN, and
blocks all incoming traffic. This presumably enables all my IoT devices to communicate with their servers (and other devices to access www etc.) by allowing them to set up TCP connections but blocks any attempts by external devices to initiate TCP connection to them, right? So I guess this provides some security but is it sufficient? What about UDP, I guess that is covered by the same rules as it doesn't specify the protocol.
Thank you again for your valuable support.
- antinodeOct 30, 2020Guru
> [...] there is an option to "Configure the second IP Address [...]
Interesting. I've not seen that sort of feature elsewhere.
> The problem seems to be in setting the WAN/Internet i/f address [...]
If you can't find a way to do that, then the project may be doomed.
> A final question - [...]
Yup. Anything (TCP, UDP, ...) incoming at the WAN/Internet interface
goes nowhere without a good reason: DMZ, UPnP, or port
forwarding/triggering.It's not so much that the router "blocks" incoming connection
requests; it's more that, without some kind of help, it has no idea
where (on the LAN) to direct them. The external system has only your
(single) public IP address with which to work, so it has no way to
address any particular device on your LAN.
Typical Internet-of-Junk gizmos establish an _outgoing_ connection to
a (cloud) server someplace, and that's not restricted by default. NAT
handles that stuff.> Thank you again for your valuable support.
I live to serve. If you ever do discover how to exploit that WAN
Ethernet port, please post.
