Rayham
Apr 12, 2021Follower
CG3000v2 Netgear Modem - Router FW V2.08.07 Genie changes don't stick & solution
Hi Everybody,
I have spent all day trying to make a few simple changes to my WiFi security.
I wanted to change the initial login password, then the SSID name, the channel number, the operating mode (WPA2) and the network pass phrase.
I have used my chrome browser pointed to 192.168.0.1 to connect to my modem and make changes. The trouble was almost any changes I made soon dissapeared after I applied the changes, and reverted back to the original settings.
On occaision I got a change through but only 1 parameter, the others reverted?
I concluded the modem software is junk.
I also discovered by trial and error - as I could not find it noted anywhere in the modem manual or on your site - that the pass phrase will not accept space characters.
Using Genie, it also did not accept some other characters like $.
Maybe this is not true and just a glitch in the Genie software? Do tell?
Solution:
Later I tried the Genie and Nighthawk apps on my ipad - both not compatible with the modem - both fails.
But - using SAFARI on my ipad air 3 to access the modem via 192.168.0.1 , I was able to make all the wanted changes! The changes stuck after I hit the Apply button! Of course I had to change the wifi settings on the ipad after changing them on the modem, as you would expect.
So Chrome on win7 pc - fails, while Safari on an ipad works? Why? Who would expect that to happen? I hope this helps someone not waste hours and hours.
I am only using Netgear because my ISP provided the modem, no choice, but from what I have read on your site, I would not touch Netgear with a 10 foot pole if I had a choice. :)
cheers,
ray.
No RepliesBe the first to reply
