racingsubby
Nov 05, 2020Follower
Change IP on Router. Default Gateway address dissappears
I'm wanting to setup this router and a 2nd network on my home system. I am wanting to having this router in my shop so I ran the cable from the house to the shop and now need to set this up. From my...
Nov 05, 2020Guru - Experienced User
Have you tried just putting it in AP mode? (access point)
That achieves the functions you're trying.
antinode
Nov 05, 2020Guru
Why? What, exactly, does "a 2nd network" mean to you? Is there some
actual problem which you are trying to solve? Care to share?
> [...] From my understanding [...]
Doesn't sound very good to me. But my understanding of your actual
goal is negligible.
> 1. Change the Router ID (a.k.a. what it shows for Default Gateway
> when I do and ipconfing).
Not a useful description of anything. Inventing your own, private
technical terms ("the Router ID") is not conducive to good
communication. Stick with the language in the User Manual and on the
management web site.
> [...] dosey-doed.....etc.
Think, for a moment, about how little useful information those
(non-)descriptions convey to the non-psychics in your audience.
Perhaps his psychic powers exceed mine. I don't know what you
actually want.
