Debe193
Oct 14, 2021Follower
change of SSID not possible
My WN604 was configured some years ago. Now I would use the WN604 for another application and tried to change the configuration. I changed the e.g. SSID in the WLAN-settings but after connecting the AP it has the old SSID again. It seems that the WN604 cannot save the new value.
1 Reply
Have you tried a simple factory reset and reinstall?
